Hi all. 2005 Tahoe with approx 140K on the odometer. battery kept running down and I found if it sat for more than a day or so it would drain. Then I thought it might be the Onstar/phone thing so pulled that fuse but didn't fix it. Did some googling and found some info on troubleshooting parasitic condition. I ran a M/M in-line and at first it wasn't working with my Craftsman meters. Turns out both had the 10A fuse blown, likely sometime in the past. Anyways, picked up a new meter and got to work. Sure enough I found the problem after just about pulling all the fuses - it was the ABS fuse and was drawing a pretty high number of mA. IIRC it dropped down to 30 or so after.
It's been out for a few weeks and no issues - except the dash light indicators. I've been driving it around trying to get the last monitor (evap) to finish and see if there are any other codes, but it is seemingly driving fine without ABS. I suppose I could just drive it as-is. If I decide to tackle it, can someone point me in the right direction for troubleshooting why the ABS fuse?
Thanks
Nick
Thanks
Nick
