2005 Chevy Tahoe start engine problem
2005TahoeDriver
I haven’t been able to drive my 2005 Chevy Tahoe for months. I just got a new battery and after installing it I attempted to start it up. The dashboard lights up just fine and everything electrical seems to be working, but when I turn the key all the way to start the engine, it just won’t start. It cranks/cycles like it’s trying to start but it just won’t start. I’m not much of a mechanic, so I’m hoping someone will point out some of the things that could be the problem..maybe a fuel line is clogged from not being started for months?
Any advice or suggestions are appreciated, please. Thank you ahead of time.
Jimmyy
Minnesota
When you turn the key to the "on" not the start can you hear the fuel pump run? It should run for a second or 2. If not hit the bottom of the gas tank and check again.
Reach under the gas tank and smack it bottom dead center with a hammer or rubber mallet a few times, then try and start it.
if it starts then you need a fuel pump, if it doesn't start then check fuel pressure, if no fuel pressure then it's the fuel pump (most likely)
if you get lucky and it starts after hitting it with a hammer the 1st time then do not park it somewhere inconvenient because it might not start again.
GPPV
