The answer is yes and no. Your front can be lowered with the keys but your rear will be higher unless you do different springs. So it is all about what you would like to spend and effort needed. If you are dead set on 33s then sure. But personally I feel like you are wasting money buying a 6”. I mean plenty of people are rolling ford keys and a rear spacer with 33s. Now they are STUFFED and do not have the articulation.x
Without knowing your intended use it is hard to make an informed recommendation.
Where I wanted ground clearance and articulation for when I am off the grid which is basically every other month.
