2003 tahoe front end.....HELP.....
juicie
I have a 2003 Tahoe that need a new grill...headlights...bumper...and hood...
I have seen where some people have done some other swaps for the front clips! Im curious as to what front ends are available for this year that will be a direct bolt up without a ton of modding...thanks
juicie
juicie
some help would be greatly appreciated...thanks
Danzigman
Galveston, TX
Install a 2001 HD Hood/Grill/Bumper combo The headlights will be the same, the HD look on a Tahoe is just different enough to get attention.
juicie
juicie
What about the 03-06 silverado front end? Correct me if I'm wrong but the parts should all interchange without any modifications?
josueh95
yes 03-06 silverado is possible all you need is the parts and i believe the support around the grille and headlights
ScottyBoy
Shreveport, La
For an 03-03 Silverado front clip, you will need EVERYTHING from the doors forward. Fenders, hood, complete bumper, all lights, grill, headlight buckets and mounting brackets, core support, and most importantly, the frame horns. You will have to cut your forms horns off with a saw all and either weld or bolt on some 03-06 Silverado frame horns.
Z-56 Hoe
What do I do????
Houston
There are all kinds of things you can do I am looking at joe gibbs Tahoe grills for ours.
juicie
juicie
so its not as simple as changing out the finders...hood and bumper? You have to do some cutting and welding ?
Z-56 Hoe
What do I do????
Houston
Yes and change out the core support and the prices behind the headlights.
juicie
juicie
Need Help
Can someone please help me..... I have done the whole silverado conversion on my tahoe minus the front bumper! I need to find the front bumper brackets that holds the bumper! I need the brackets that connect to the frame horn
johnnycuatro
