2001 Yukon keyless entry remote
zeakieb1
I'm new on this forum, can anybody tell me how to program a new aftermarket remote without having the old one. I've tried the instructions that came with them I checked the fcc I'd number and part number everything seems to be in order however I can't program them. I was told I needed to take it to a locksmith or dealer, is this true?
St. Louis
Yup, or someone with a Tech2 that can put it into keyless remote learn mode.
Also, when you program remotes you need to do all the remotes you have. You can't just add/program a single remote without losing any other remote programs. If you have 2 remotes, program them both, 3 remotes program all 3, 4 etc.
Fless
Super Moderator
Elev 5,280
Is the remote programming for the '01 different from the later NBS models? I don't need a Tech 2 to program my 2004's aftermarkets remotes, just the right procedure.
Fless
Super Moderator
Elev 5,280
Would you be able to post up the procedure you're using for your 2001 remote programming?
EDIT: is the procedure at this site the one that you're using?
https://northcoastkeyless.com/2001-gmc-yukon-xl-keyless-entry-remote-programming-instructions/
St. Louis
I never knew about this procedure. It doesn't even say anything about doing this in the owners manual for my 01
Nope, my manual says take it to the dealer. I found out about it when I ordered new fobs and the aftermarket seller had instructions. Bastards.
Fless
Super Moderator
Elev 5,280
Same here. Mine came with only one FOB and when I did the research for aftermarket FOBs I found this.
Same with my 08 Silverado and the chip key. Manual says dealer only. I went to a local hardware store that advertised chip key programming and they wanted something like $70 for a key. Then I found out I can buy the key online, have them cut it, and program it myself. Saved $50 plus it came with a fob that I also programmed.
fast-cheap-right
