Hello new member here. I have a 2001 Suburban 2500 LT with the 8.1 and the weird dual fuel tank system.
When I fill the gas tank until the pump clicks off, it will flood the motor out at idle. If I hold the gas pedal down it will keep running. I do not overfill the tank.
If I shut the pump off a couple of gallons before full there is no issue.
I have replaced the purge solenoid on the intake manifold, the canister vent by the rear axle, and cleaned out the vent that is up near the fill tube. When the vehicle floods out, I notice the canister vent by the rear axle will have fuel in it if I unhook it.
Removing the gas cap does not make a difference.
Any suggestions? I haven’t replaced the charcoal canister yet as this doesn’t seem to be caused by a failing charcoal canister.
