2000-2006 Chevy Tahoe Front Brake Pad & Rotor Kit Semi-Metallic
1ATony
CHECK US OUT HERE FOR GREAT PRICES 2000-2006 Chevy Tahoe Front Brake Pad & Rotor Kit Semi-Metallic
FREE SHIPPING IN THE LOWER 48 STATES
Hearing squeaking noises from the wheels? This may be the wear tabs on the brake shoes saying, "it is time for replacement." Aging brakes can also result in a pulsation from the brake pedal or long stopping distances. Brakes should be inspected every 10,000 miles or any time the tires are removed. They may need frequent replacement such as every 20,000 miles if used in stop and go traffic. Brakes can last longer if the vehicle is used primarily for long highway trips.
Brake Pad Specifications:
4 Piece FRONT Brake Pad Set
No core charge
Direct replacement
Professional Grade PREMIUM SEMI-METALLIC Disc Brake Pads
Pad Length: 7 Inches
Fits both 2WD or 4WD vehicles unless specified
Brake Rotor Specifications:
Comes as a PAIR
Fits both LH (Driver Side) & RH (Passenger Side) FRONT
Replaces dealer part numbers: 18060214, 15716362
Fit 6 Stud Wheels
Direct replacements
This front brake pad & rotor kit makes a great replacement and has an excellent value over the price of dealer brake pads & rotors.
1 Year Warranty
This item is backed by a 1 Year Manufacturers Warranty. In the event this item should fail during intended use, we will replace the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty.
MightyMouse383
