2-Channel Dash Cam Install
operator5362flink
Maryland
No, with the fuse tap the original fuse protects the two existing circuits just as it did before, and the new fuse protects a NEW circuit for your accessory.
Rev_Night
What instructions are you referring to? When I got my Micro3 fuses in, the "instructions" just said to plug it in ha. Written in English but barely
Rev_Night
Yeah, one row and another row. It doesn't say if the rows matter re: old or new fuse
Rev_Night
hmmm I connected everything correctly (i think?) but the camera is not turning on. I know the camera is still good because it works when I use the cig lighter power cable. Both fuse taps appear to be inserted flush and fit perfectly.
F26
-Accessory
-Micro 3
-Pre-existing 10a in row closest to prongs
-Vendor provided 5a in row farthest from prongs
F44
-Constant/Battery
-Micro2
-Since this slot was empty in the fuse box, I put both vendor provided 5a in the fuse rows
Ground wire is attached to frame bolt
Thoughts:
1. Not super happy with one of the crimps. One of the wires crimped perfectly, the other required that I fold in the metal to create a better contact surface. I crimped using a multi-use wire splitter. The not great crimp (i tried a few times) holds but I can easily rip it out if I wanted to.
2. There was a previous post here about how his fuse 44, the hot line was switched. I believe his hot line was on the left, and the OPs was on the right. I used 2 different voltage pens and I was unable to determine which side was hot.
Rev_Night
Sounds good. Its raining today and my tahoe can't fit in my single car garage. I will post tomorrow
Danayala
