Where is it leaking?
Reman pumps are hit or miss, but your odds probably improve if you don’t get the cheapest one available.
There will be two choices, one with the EVO bypass pipe installed or one without it since they don’t sell the EVO solenoid valve anymore. You’d transfer your parts to the new pump in that case.
For a pump with the bypass already installed, just connect the hose and leave the EVO sensor harness tied up somewhere.
A third option is to buy the bypass line separately (but it’s a $60 GM part) and put it on a pump that doesn’t have it already installed.
I’d buy the new pump with the bypass line already installed. Hit it with some brake clean to get the spray paint off of the fittings. It’ll be easier to check for leaks then.
