Hi
I have a 96 Tahoe, mfg date 5/96.
I'm trying to understand the wiring on the front actuator. The axle actuator has been upgraded to the electric motor. The new harness is a 3 pin connector with colors Brown, Black and Light Blue.
The actuator will extend but not retract.
When I check the connector with voltmeter in 2HI with key on, I have +12Vdc between Black and Lt Blue and +12Vdc between Black and Brown.
When i push 4HI, it is the same as above.
Does anyone have experience with the 3 Pin harness / actuator?
Thanks
Thanks
