1995 Yukon Sport LS 6.0 4L80E questions
Badfish859
Hebron, KY
What's up, guys! I just picked up my first 1995 Yukon Sport 4x4, and I've got a few questions for those of you who have done an LS swap in a 4x4 GMT400.
I'm planning to LS swap it in the spring/summer of next year. I just secured a low-mileage 6.0L, and my plan is to pair it with a 4L80E 4x4 transmission.
I'm looking for advice from anyone who's done this swap, especially if you've kept your Yukon 4x4.
A couple of questions:
  • What adapter did you use to mate the 4L80E to the factory NP241 transfer case? GM 15654927 what I've found so far.
  • Did you run into any fitment issues with the transmission or transfer case?
  • Was any special programming required in HP Tuners to get everything working correctly? As far 4X4. I've done a few 2wd LS Swaps and know what's envoled with that.
I'd appreciate any advice, recommendations, or lessons learned from those of you who have been through this swap!
Thanks in advance!
Marky Dissod
As far as 4X4. I've done a few 2wd LS Swaps and know what's involed with that.
Although I could very well be wrong, I do not believe that HPTuners has (or will ever give a schidt about) the ability to tune OBD1 Vortec pcms.
If you convert to a 12200411 / P01 pcm, which is tedious but not difficult, you should be able to make it happen.
However unless you absolutely require the 4L80E, you may be wise to seriously consider keeping it working with the 4L65E.
Badfish859
Badfish859
Hebron, KY
I will be running a P59 LS ECU that will control the 6.0 LS and the 4L80E transmission with A OBD2 connector.. an complete removing all the orginal OBD1 harness ecm... everything.
Mariam26A
