I need the torque specs for an 09 tahoe!
That really narrows it down....
Did you want us to start at the front and work back for every nut and bolt or would you prefer a side to side approach???
Or are you asking for the HP/TQ specs???
I mean.. if you're willing that would be awesome! But for now I'll settle for anything related to the front suspension.
Shock Absorber Upper Mounting nuts:
37 ft-lbs
Shock Absorber Lower Mounting bolts:
37 ft-lbs
Upper control arm pivot bolt nuts:
140 ft-lbs
Lower control arm pivot bolt nuts:
129 ft-lbs
Balljoint-To-Steering Knuckle Nut:
Upper 37 ft-lbs
Lower 92 ft-lbs
Tie rod end to steering knuckle nut:
44 ft-lbs
Sway bar:
Link Nut 17 ft-lbs
Clamp bolt 37 ft-lbs
Hub bearing assembly to steering knuckle:
133 ft-lbs
