mikechrisclark
- Joined
- Oct 16, 2021
- Posts
- 2
- Reaction score
- 2
I have an 07 yukon 5.3l flex fuel with 195,000 miles. I know the P0300 code has been addressed a lot but mine may take the cake and I’m lost.
I spend $4800 to have lifters replaced by certified mechanics. Heads were milled and the repair was done correctly. I had 2 lifters go bad and had misfire and p0300 code. I got truck back and it was running great. Like new. I hardly use this truck except to tow camper and boat. It has only 3000 miles on engine after lifter repair. Not a daily driver. It has sat most of winter being started once a week for five minutes each time. When I finally decided to take it to the store it had no power, misfired, shifted hard and felt like it did before lifters were changed.
I removed valve covers. All rockers move, push rods move. Seems to be ok with lifters. So I have replaced, all coils, plugs, plug wires, fuel injectors, o2 sensors. Still not running right. I have a tuner to delete 4 cylinder mode but it has issues with tuner on or off.
I am at a lose for what’s next. I did notice when I changed fuel injectors the pressure relief valve on fuel rail didn’t even drip fuel when I pushed it in to take pressure off system. Will it still run, even like crap, with a bad fuel pump or clogged fuel filter? It should have sprayed out shouldn’t it? I’m in need of help. I have spent way more on engine and parts than the truck is worth at this point. Thank you for any advice.
