'07 Hoe Comp/Temp display not working/intermittent at best...
89Suburban
Bull in the china shop
SE PA
'07 Hoe Comp/Temp display not working/intermittent at best. Usally never on, then pops on once in a while. The buttons light up at night when the lights are on. Any advice on this issue? thanks.
display inside the mirror is either going out or has loose solder, when mine did that on my nbs I just replaced it, some guys take them apart and try to fix them.
89Suburban
89Suburban
SE PA
Thanks for the reply Wes. What are replacement options? Is there aftermarket?
I don't think there is really any oem type aftermarket out there, I have never heard of one anyway. easiest is just get a used one from a junkyard or ebay.
new ones are not cheap even on rockauto they run 300-450 depending on your options (there is basically 3 different versions).
my nbs was easy just went to the pick n pull junkyard found one that matched and cost me like $20
89Suburban
89Suburban
SE PA
Understood, thanks again.
2DoeProjectHoe
