06 yukon tires
tna0066
I have a 06 yukon xl. A buddy of mine has 18" tires that are almost brand new and would love to throw on it. I have stock 17" rims. Can i throw 18" rims on this thing without having to jack suspension? They're not low pro's or anything. They are more aggressive tires which would be better for the area in which i live. Thanks!
livingez_123
Sandy, OR
Shouldn't be a problem unless your lowered a bunch. If your stock height, and the tire isn't to much taller then your 17" you should be ok. Give it a try before you buy.
JochenWoern
Sacramento, CA
^ +1 - As long as your tire is not much taller and/or wider than what you are running today, it should be no problem at all.
I am running 20" inch rims with 275/55 tires on them with no issue at all.
Any idea what size tire is on the 18" 's ???
mjordangray
