05 Tahoe with Tbar leveling kit
Skunkape
4x4 Tahoe has 1.5-2" leveling keys, 1" spacers in rear springs and it handles like a boat. It has rancho shocks, moog stabilizer links, sway bar bushings and bump stops.
I'm thinking of losing the spacers, installing new coil springs, pads and better sway bars.
Any thoughts or recommendations?
Thanks for reading.
dps01
Senior Member
Navy Supporting Member
N. TEXAS
Thanks for reading.
Not sure of your mileage or how new your shocks are, or general condition of your existing bushings etc., but if they are old or unknown age, that’s a good place to start. Depending on ultimate use, Z71 springs will help (but will lift the rear when unloaded (lose the 1” spacers and it may be close to current ride height). Air bladders in the rear springs will help. Lots of folks swear by Hellwig anti-sway bars front and rear, but they are proud $$ of their stuff (on my want list personally). Another thing is bump stops. The LCA should be in contact with the bump stop. Many times when torsion bars are cranked, they are not and larger bump stops are needed such as Timbren (again on the pricey side).
Front bump stop comparison
Gap on LCA before replacement
S
Skunkape
The LCA before pic looks exactly like my rig. I didn't know the stops had to be in contact. It's the same in the back. No wonder it corners so bad. Thanks so much!
She's got about 335k on it and the parts I put on are about a year old.
Thanks again dps01!
dps01
Senior Member
N. TEXAS
Although the front stops are sometimes called "bump" stops, the correct name is "jounce" stop. Different functionality between the two.
Stand corrected. Proper terminology is important.
Thanks.
dps01
Senior Member
N. TEXAS
Thanks again dps01!
In the back, there will be a gap between the bump stop and axle unless heavily loaded / worn springs. Only the front jounce stop is in contact with the LCA.
Replaced the springs and it raised the rear back to original ride height for a Z71; ~ 1.25” over the original springs w/~200K miles at the time.
Z71 springs; air bladder; Timbren rear bump stop.
S
Skunkape
Got it. I've got 4 new "jounce" stops and coil spring pads on the way. After I remove the 1" spacers under the rear coils, I'll check it for ride height and drivability. I might have to replace the original springs too. I'll keep you posted and thanks again.
S
Skunkape
Just an update;
I went with iiLentes GMFK15A front jounce stops, the Timbren were too much $. Added new Moog 81071 coil springs and new insulators. It made a world of difference!
Measured 14 5/8" to center of lca pin bolts and between 47 1/2 & 47 3/4" at all 4 wheel wells. Really happy with it and it drives well.
Charli1964
