03 Yukon Misfire
Chevykid404
I am completely stumped on finding the misfire on my 03 Yukon 5.3L. I have a misfire that I cannot fix. Due to the misfire I cannot get my emissions done to register the Yukon. I just recently replaced the fuel pump, fuel filter, fuel injectors, coil packs, spark plugs and wires. The codes on the ODB2 reads P0200, P0300, and P0332. I am at a loss as to what the issue is. Does anyone have any experience with this issue? I really need my Yukon and don’t want to continue throwing money at parts and it do not fix the problem. My Yukon is burning gas fast and when stepping on the accelerator is not getting all the power behind it.
Scottydoggs
NJ
p0334 is a knock sensor code, 300 is random misfires, p0200 is cylinder two injector circuit.
check over the wire to the injector plug, and the harness for damage. you can also swap the injector with the one next to it to see if the code moves to a p0400 aka cylinder 4 thats next to cyl 2, if the code moves that injector is bad. you can also take small bulb like a parking running light from a head light, push that into the injector plug fire the engine up see if the bulb flashes. test light also works for this.
depending on miles clogged cats can cause the p0300 multiple misfires. cause the lack in power and sucking down gas.
Fless
Super Moderator
Elev 5,280
Save your old parts since they may be better than any aftermarket parts. No-name injectors, especially, may cause more problems than they solve.
Follow the link below for the P0200 diagnostic procedure, but first verify your specific vehicle and change using the links at the top of the browser window.
alpha_omega
Michigan
The knock sensors on those are kind of a PITA to get to. They are under the intake and really should be sealed (dammed) with some silicone after installing to prevent water intrusion. Plan to spend a good couple hours or more if you’re not familiar with vehicles and plan on doing it yourself. It’s an easy job, just tedious.
You’ll want new knock sensors and new intake gaskets. Possibly a new spark plug and injector depending on how far you’ve driven with it missing.
Take a picture of your RPO code sheet (found in the glovebox or maybe behind the passenger sun visor) and have your VIN. You’ll want both when you go to order your parts (VIN because the parts are different being a regular vs flex vs hybrid - and before anyone says otherwise, yes I know the hybrids weren’t out back then).
Fless
Super Moderator
Elev 5,280
If you do the knock sensors, use GM OE sensors and a new harness. When you reinstall the knock sensors be sure to add the RTV PARTIAL dams in the right place:
(this TSB is for the rear sensor replacement, but the dam also applies to the front sensor)
