Coastalyetti
- Joined
- Jun 18, 2022
- Posts
- 2
- Reaction score
- 2
New to the forum, any insight appreciated. I have a 2001 Yukon 4x4 with 168k. After some hard driving to a job site in the mountains truck started making a low pitch hiss when braking, kinda like a dryer vent sounds like outside the house. Brakes were pretty worn so replaced pads, rotors and park brake shoes. Still makes noise. Calipers seem fine no leaks or corrosion, lines and fluid seem good, axle seals dry, parking brake works and pedal feels normal. Then I noticed a very similar or same noise when it was parked downhill at idle. Could it be the same issue??Can’t tell where it’s coming from, engine bay or underneath. Truck leaks oil from valve covers and somewhere else lower. I had a shop replace the air pump and check valves, pump was full of water and died, to pass Ca smog two years ago. I can’t tell if it’s getting louder or I’m getting more irratated with it. Oh and the abs and park brake lights started coming on randomly, gotta love it. Where should I start????
