01 yukon no start
Yukon82291
Goffstown NH
:emotions122: I have a 01 Yukon 5.3 that has been sitting in my yard for the past 3 weeks (blown tranny) been going out to start it up every other day or so and started up just fine every time, today i went to do so, not so much. All the lights come on like everything is fine, i hear the fuel pump kick on, turn the key to crank and all i hear is a click in the electrical box, start dosent turn over. Any idea?
---------- Post added at 03:04 PM ---------- Previous post was at 03:02 PM ----------
Starter dosent turn over**
kschumake83
Orefield, PA
Try clicking the key a couple times in a row or tapping the starter with a hammer a couple times. If it is the starter it should turn over after trying this. If not it is probably your battery, do all the lights shut off when you turn the key to start and then turn back on when you release?
Y
Yukon82291
Goffstown NH
tried jumping it, nothing took the battery out and brought it to advance to get tested and they said it was fine, guess ill buy a starter :emotions122:
---------- Post added at 09:10 PM ---------- Previous post was at 08:51 PM ----------
just noticed im missing my ground strap to the hood, any way that could be the problem?
Crowder99Yukon
Did you try tapping the starter?
Sent from my HTC One S using Tapatalk 2
Y
Yukon82291
Goffstown NH
had the battery tested the day i i wrote this, it tested fine. I was mad at the truck and didnt touch it till today, i went out side to see if it would start for ***** and giggle, fired right up?! Bad ground maybe?
Kjg238
