I took the driver door innards apart to replace the door lock actuator and now I see the above message on the dash even when the door is firmly closed. Since there isn’t a switch in the door hinge area anymore, the switch must be in the actuator and must be communicated through the connectors that are under the switch plate at the driver’s left hand. Does anyone know which connector is the culprit or the cause of the erroneous message?
This is my first attempt at posting so please forgive the double posting in Conversations.
