VLEDS did not fit
Bigfoot16
Bigfoot16
I talked to VLEDs and they confirmed the information I received was incorrect and the bulb will not work. I sent them a picture of the stock bulb and I have new set coming. They were super cool to work with and apologized for sending the incorrect product. Thanks for the input guys....Mad Maxx... next time I'll send the picture first to double check...:)
whitlecj
Which bulbs did you end of getting. Do you like the VLED's.
Steve737
Montgomery TX
I just installed mine last week. You need to modify them slightly. They will tell you that if you call vled. I used the old bulb and trimmed the locking tab. You Also need to cut off one of the raised parts on the side. Super easy took No time at all. Vled said the new 2016's are slightly different for some reason. Hope that helps steve
Demer
Eagle, ID
I installed these on my 2016 a few days ago and there was no modifying needed. Are the Tahoes different than the Yukons?
Steve737
Montgomery TX
Not sure. But I had to modify mine. when I called to order they told me I would need to modify slightly.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
i posted the vleds part number on my build thread. I love em
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Look at my build thread my vleds work great
dvnt
