Charlie207
LFOD, New Hampshire
Replaced the valve cover gaskets, and cleaned up the schmoo from the valve covers.
Couldn't even start installing this clamp, because the ground strap bolt is King-Konged into the head. I guess I'll try to go up from below, but will have to remove the front drive-shaft.
I just noticed the 6.2 stamped under one of the valve covers. Is that because the 5.3 and 6.2 share the same heads?
Also, the Fel-Pro gasket set came with an extra gasket, and I have no idea where it is supposed to go. Looks like this:
Any clue?
Any clue?
that gasket sets covers 99-20 could go to anything, off hand I would guess some form of pcv valve, it's not applicable for all.
ivin74
05 NBS Nali
Htown, Texas
Any clue?
That gasket is for the old LS factory E.G.R. and A.I.R. connection if I'm not mistaken.
