99 Chevy Tahoe LS 4x4 - Lower Control Arm
MushroomMang
Atlanta
Been driving my 99 Tahoe for about 10 years now and am needing to replace/service the front end. I'm unable to find any lower control arms. Anyone have any leads? All i can find are for the RWD. Needing the 4x4 for the front end torsion bar.
Thanks
the 18th letter
Northern New Jersey
Thanks
Going thru the same thing. I was advised to see if I can get away with changing the bushings and ball joints. Still working to see if that was good advice or not...
east302
Mississippi
Here’s a discussion on it.
Cliff’s Notes version: the stock LCA is not available as an aftermarket part. Junkyard, eBay, etc. But the LCA on 4x4 Chevrolet Astro vans can be made to work if bushing replacement is not feasible.
ct99
Good morning, I am also having this problem. I bought new bushings but they are loose. Parts store Guy said could be bad housing on the LCA. Can't find a replacement other than junkyard. Does the astro van have the same setup? I appreciate your time . No one I've talked to has an answer.
ciscotex
