Question about the TBSS / NNBS intake upgrade
I'm either misremembering, or my knowledge on the topic is old. Thank you for the correction! And the details are really appreciated too!
The internet has been around for a few decades now so there's an overabundance of misinformation. I'm just a guy (Or girl? Or bot?) on the internet so I could be leading you astray. You never know anyone or their agenda. *suspicious stare*
S33k3r
Dallas, Texas
When people stare at you and you correct them with, "My eyes are up here," which set do you point at?
Alex_M
Stage 2 and the heads, headers, etc... I'd say ~420 at the crank. Mine is similar to yours, just with nearly-stock, mildly-shaved heads. Calculating the ET with the weight, etc., 400ish at the crank is a close estimate for mine. It's right in line with the '09 6.2/2WD Tahoe. It's difficult to say for sure what's lost through the trans. Actually, mine might be doing a little better than I'm thinking cuz it's matching the 6.2 Tahoe with a 4L60. The 6.2 has a 6L80. Richard's figures are always high cuz his dyno mules are with no accessories and an electric water pump, a cool ~75° dyno cell, etc. His before-and-afters are for comparing the mods themselves and not for relating to real-world figures.
For calculating fuel demand, you want to go by those higher numbers (ie. without accessories or drive train losses) because that is the true power your motor is making. It still has to make the power that is lost through accessories and drivetrain, therefore needs the fuel supply to make that higher number. Rich's videos should give you a pretty good baseline for estimating fuel demand even though (partly because?) they are higher numbers than you'll see in the truck.
adriver
Here are the adapters to make whichever injectors fit properly with whichever rail.
You can find the adapter harnesses for about $50 from all over.
Sam Harris
Sam Harris
Texas
View attachment 399383View attachment 399384View attachment 399385
Great info! Thank you.
mattt
Good info there from adriver. Likely the same info in the attachment, but here is a website that has all the same info that I have found useful when looking up injectors.
Sam Harris
Sam Harris
Texas
Thank you!
madmax442
