payload on 2023 suburban diesel premier trim?
ttttttt unit
can anyone help me get data on this please- looking to order a diesel suburban premier, but need to know payload capacity
i know these vary a bit due to options but looking for some real world examples out there
if you have this trim with the 3.0 diesel, share your payload capacity please!
WalleyeMikeIII
Sunny and Snowy Minnesota
So a 5.3 2wd is rated to tow more than the 3.0 and 6.2 in max trailering package.... WTF...
Yes, as the weight of the transfer case, front differential, front axels, hubs, etc is gone, so you can add it to the payload and/or GCVWR
There was a time, before every block was Aluminum, where the 4WD got aluminum block engines and the 2WD got Cast Iron, since the weight was saved on the 4WD hardware.
