Lifted/Leveled 2021 - Postem Up
Hunter Linn
Tuscaloosa, Alabama
So I finally got my RC 3.5” lift on yesterday afternoon with 35x12.5 Venom RT tires (I know I will get push back for these but I got them at a steal) and Bora 1.5” spacers on front (they only had 2 in stock yesterday) the rear spacers will be sent to my house next week and I will put them on then. Here’s one photo. I will get more this weekend.
Hunter Linn
Tuscaloosa, Alabama
It does sit level but the photo was taken on a slanted parking spot
nick14226
Looks great!
Definitely looks taller than my 2” on 33’s02937B57-32D1-4184-8F3E-BBAF063D6743.jpeg
Nokturnal
My math has that at a -10 offset for those guys looking at wheels with -12, -18 offsets.
+28 mm - 38mm (1.5”) = -10mm
nick14226
Keep in mind the stock wheels are 9" wide though, most aftermarket wheels with those offsets are 10" wide which changes inner clearance and outer position.
Trailzrider
SoCal
I ended up going #kingshocks, 285/75-17 #toyotmt #methodracewheels #mazzulaoffoad UCA's #amppowerboards I need to re-valve the kings for rutted fire roads. I will try front 10/10-Flutter-17/17 and rear 10/10-Flutter-15/15 I did have to do some triming for the front. Once I can afford to do LT right I will see what #lsk has to offer.
d_hawk
A little off topic from shock valving…. I notice you have added an aftermarket recovery point to the front of your Tahoe. Could you post some closeup pictures, manufacturer and part number for the shackle setup and any installation notes you might have?
I have a high country suburban (same non Z71 bumper setup as you) and have wanted to add a front recovery point, the Z71 recovery hooks bolt up but don’t have bumper clearance to be useful.
Jhmjr
