Radiator fan runs when engine is cold
If the computer decides to, my electric fans run during remote start. GMT900s.
The conventional clutch fan on the 900s flows more air than two 700 watt electric fans. Don't recall how much anymore.
Marky Dissod
Over as little as 1000 engine RpM, I'd be willing to bet that that's true.
If I were in the market for a GMT900, my only questions would be:
Does the mech fan flow more air than two OE electric fans AT ENGINE IDLE?
Is it enough for the AC to continue to perform well at idle even while stopped in traffic @ 45C / 113F outside?
Just noticed you said 'two 700 watt electric fans'.
Guessing those are NOT OE for GMT900s?
Many GMT900s come factory equipped with 700 watt cooling fans. All three of my trucks have them.
I don't have a 2500 Suburban or Yukon XL, those have a mechanical clutch fan. Let's ask a few. @Derick @intheburbs @Moosemoon
The 900s come with clutch fans? I thought they were all electric for NNBS.
Shackman7878
San Bernardino
I have a 09 Yukon XL (gmt900) was thinking about ditching the clutch fan but cant find a decent kit or write up that dose not involve reprogramming something after or having to new temp switch, or something you stick in the radiator. I noticed it sounds like a jet engine in the morning until the engine warms up.
Video on how much power it robs -
mattbta
Frisco, TX
Based on my preliminary experience with the e-fan conversion here are my thoughts, with more to come as we ramp into Texas summer:
Idle/low speed AC performance: Electric fans
Highway (55+) AC performance: Mechanical fan
Butt-o-meter (SOTP) go-fast: Electric fans
As I did the programming to turn the e-fans on, I know that I used to stock setting of 45MPH to turn the fans off, so it reasons that the highway performance is better with a spinning mech fan. Hopefully that's the case, or I'm facing more AC repairs. It used to freeze my face off. Now it's just "cool". I think I measured high 40's at the vent.
I still think I'm ok with this trade-off if it is legitimate, because idle/traffic speeds AC performance have always been less than desired. I'll report back when we get hotter and I drive it more...I'm still not driving much at all.
Juju14
