J5races
- Joined
- Feb 3, 2023
- Posts
- 22
- Reaction score
- 22
Hello all,
I have been dreaming of having a boosted LS (I know I actually have a LT) for years. I finally got the funds together to purchase a Whipple Gen V 3.0L kit and installed it. It runs great and I couldn't be happier.
If anyone is planning to get this kit, there were several issues I ran into during the install (Parts that were not shipped with the kit but should have been, Things that needed to be modified to fit, etc). Whipple is great and overnight things they're missing as I discovered them missing.
I have mounted a cheap Jungle site Oil separator can on the Driver side fender. The picture with the heater hoses is where the instructions tell you to bend the inner hose, but you need to bend the outer as we'll. This is after I had it all done but kept smelling coolant after driving so I took these hoses off and bend the outer pipe also to get clearance. As you can see its a very tight fit to the firewall.
I have seen 8.3 PSI max so far. wonder how much its suppose to make with stock pulley.
Jon
Jon
