Wheel spacer’s
a4edwin
ny
Anybody using wheel spacers on their non lifted ride. My factory 20’s on stock suspension look like they could be pushed out a little more. If you have post some pics even if lowered
Trey Hardy
Eastern North Carolina
2” leveling kit
2” wheel spacers front and rear
24x10 snowflake replicas
33/12.50 rbp mud terrains
If you want the tires to end closer to the fender wall, then get a wider tire that fits on your stock wheel without rubbing.
For me, going to a 305 width moved the outer wall of the tire closer to the the fender wall. No spacers or special wheel offset needed.
petethepug
Michael
SoCal
I'll have .5" spacers on the front of my Esky when the BBK goes on. Another similar Esky EXT is already running them on the same BBK. It's pretty much unnoticeable. .5" longer studs were added and the wheel caps went back on without interference. The other guy is putting on some kind of new intake system.
Banjomatic
