RocketcCutlass
- Joined
- Jan 26, 2023
- Posts
- 22
- Reaction score
- 26
Ok so all sensors have been replaced a while ago except crank sensor. Plugs and wires done as well. All GM/AC Delco parts. I replaced all injectors last week and it’s running super rich. So much so it through the P0172, P0175, and P0420 low catalyst efficiency codes this morning. What’s weird is I put the range afm disabler on right after running it monitoring the fuel trims the day I changed the injectors and it didn’t throw any codes at all after a couple hundred miles of driving. This morning on the way to work, just a 10 mile drive, is when it threw the codes. It was only after taking off the range module to monitor the fuel trims to see if it learned new ones. I had been driving all week with the range module on with no issues. I’m wondering if the range module is adjusting the fuel trims enough to stop it from throwing codes. Also it run’s absolutely fine and smooth as butter. Oh and I also did a crank sensor relearn, fuel trim relearn and all the other relearns I could do with my innova tool. Any ideas?
