LargER L59 V8 oil filter part number
Marky Dissod
Typically I mix'n'match whichever brand motor oil happens to be cheapest, but only if it's 0W30.
Yday my Tahoe told me to 'Change Engine Oil', just shy of 4,000 miles. Next time I'll change @ 3500 miles.
I am vehemently against using a tiny oil filter. I'd much prefer to use one with extra oil capacity.
Ok if I ask for some part numberS for larger oil filters for my Tahoe's L59?
Since I no longer drive very aggressively, my guess is 0W30 & changing oil and filter more often is more important than using THE ULTIMATE oil and filter, which is why I'm asking for part numberS.
Thanks in advance.
M
Marky Dissod
Read something like this a few times:
GM changed the ACDelco oil filter thread design for Gen 4 V8 engines.
Gen 3 V8 PF46/PF61 used SAE thread. For Gen 3 PF46 is short, PF61 is longer.
Gen 4 V8 PF48/PF63 use metric thread. For Gen 4 PF48 is short, PF63 is longer.
Does that seem right?
S33k3r
Dallas, Texas
Would someone mind educating me on this, please? Why is having a bigger oil filter better? Is it because you can go longer between oil changes? I get that a bigger filter can filter more oil at once due to greater surface area. Anyway, thanks.
M
Marky Dissod
ACDelco PF61
Looking for equivalents. To be clear, I am NOT sure if these part numbers are compatible.
If anyone has any idea if these filters are interchangeable, please speak up.
Fram 9837? or 3675?
Wix 51522?
Mobil1 M1-206?
Seems like it was easier to find the part numbers that cross referenced against any other part number years ago ...
M
Marky Dissod
AC Delco PF61 Equivalents:
GM 19210285 or 25014377? or 25014878?
Fram 9837? or 3675? or 3429?
Wix 51522 or 51045
Mobil1 M1-206
M
Marky Dissod
As of today, this is the list I've been able to compile of largER oil filters compatible with ACDelco PF61
AMSOIL EAO64
CARQUEST 85522
CHAMP PH59
CHAMPION OF07
CHAMPION OF30
FEDERATED LF164F
FEDERATED LF487F
FIRESTONE L25288
FRAM PH3675
FRAM PH9837
GM 19210285
GM 25014377
GM 25014748
HASTINGS LF164
HASTINGS LF487
KENDALL K9
LUBERFINER PH922
MOBIL MO5288
MOBIL ONE M1-206
NAPA 1522
NAPA ProSelect 21522
PARTSMASTER 13675
PARTSMASTER 61522
PENNZOIL PZ28
PERFORMAX PO-28
PRONTO PO3675
PRONTO PO487
PRONTO PO5288
PRO-TEC 166
PUROLATOR L25288
PUROLATOR PureONE PL25288
QUAKER STATE QS3675A
SHELL SH43
STP S3675
TEXACO T-43
VALVOLINE VO31
WARNER WPH59
WIX 51522
So far as I know they all share 13/16-16 thread, 4.526" height, 2.921 Top OD, 2.430 Gasket ID, 2.734 Gasket OD
