2003 Chevy Tahoe- Transmission Fluid Change
pauly1119
Coils no, only if they go bad. Hoses and belts yes actually just did them. My round trip with my Yukon to work is 180 miles twice a week all highway and the last thing I want is to get stuck on the highway. I want to make this 22 year old truck last 4 more years and I’m retiring. It only has 107k miles. I’m also a little OCD with general maintenance according to all my friends. I actually enjoy working on it to a degree though.
You must just have bad luck or you overheated the camaro's tranny therefore overheated the shift solenoids. In all the 4L60E's that I've owned and still own, I have never had a shift solenoid fail. Do you replace your ignition coils because they have 150k miles on them? A shift solenoid will last alot longer than a belt or hose will.
ScottyBoy
Shreveport, La
Here's a pretty detailed write up I did on another forum back in the day about changing and flushing the transmission fluid and replacing the pan gasket and filter. This was even before I joined TahoeYukonForum.
nonickatall
Germany
Very good write up.... :thumbsup:
I would add two things. It is not necessary to exchange the oil filter every time you do it. Different to an engine oil filter, the filter only catch bigger debris. And metal wear sticks on the magnet. Its good to exchange the filter, but a lot of people are affraid of that and don't do the oil change. Better 10 Oilchange without filter change, than no Oilchange.
Without filter change you change the oil in 30 minutes, without need to lift the car.
The adapter is fine but not neccesarry. You need two people to change the oil anyway, one to start the engine and one to fill the oil. This person can also keep the hose on the oil cooler, there is not much pressure.
And pleas use only Dexron VI
And don't forget to change transfer case Oil, differential rear and front and steering fluid. The Dexron VI you can also use for that, except for the differentials.
If you have the AUTO 2-speed transfer case it takes Auto Trak II fluid, not Dexron VI.
tomloans
When you say has a step in it, what do you mean?
Step pan...
No Step pan ( flat bottom - not two levels)...
These are jut an example. The step pan has a little step in it and needs a deep filter to reach the lower level.
DefiantOne
