dkad260
There’s a reason for the socket end on ratchet side the plug socket. It makes the perfect length to get #8 out. No other extensions, etc. Try it!
Ha, that's definitely the better way for that plug....all those years I've used an extension and never thought about that. Would have provided a bit more room against the ratchet head.
I used a short extension which is close to that length, but a tad longer.
Thanks for the tip, will surely try that on the next job.:cheers:
89Suburban
Bull in the china shop
SE PA
jared999
I still need to do this.
It's easy with the right tools. I considered heating my cutting blade up, but that would heat up the entire blade and handle. Didn't seem like the right way. I then used a heat gun and heated sections of area itself that I was going to cut. The blade went through it nice and easy.
Bought my kit off rock auto
AirJordan613
Northeast Ohio
Added a cabin filter to my Tahoe. It's a mod and requires some cutting as the car was not optioned for it. Job is very simple. I did a quick search and did not see a DIY on it. The mod does come with instructions, but I could create a DIY that may be useful to someone..
View attachment 393883View attachment 393884View attachment 393886
Great mod. I got a carbon air filter to go with it. I think it makes a difference vs my Jeep that doesn’t have one and doesn’t have aftermarket support to add one.
staffie
