dkad260
I get it if you have a bad back, it can contort you in weird ways.
Overall not too bad, there was adequate room but tight. Was a number of different small extension combinations for the full process.
Screenshot_20230305-174217_Gallery.jpg The stool positioned in this manner really makes a big difference with a firm footing.
89Suburban
Bull in the china shop
SE PA
#8 plug trick: use a regular depth 3/4” socket on the end of a magnetic 5/8” plug socket. Put the plug socket on the plug, and use the ratchet/ 3/4” socket combo to wrench it. There’s a reason for the socket end on ratchet side the plug socket. It makes the perfect length to get #8 out. No other extensions, etc. Try it!
KCW_Andrew
