the blur
105,000 miles. I can feel the bang and hear the bang from a stop light. Is it the dreaded drivers side motor mount ?
4WD, LTZ 2013 Suburban.
Need to know model. AWD will make a difference.105,000 miles. I can feel the bang and hear the bang from a stop light. Is it the dreaded drivers side motor mount ?
Motor mounts and/or frt carrier/differential bushings/mounts105,000 miles. I can feel the bang and hear the bang from a stop light. Is it the dreaded drivers side motor mount ?
Awesome - thanks. The diff mounts Don mentioned usually fail long after the motor mounts do because they're not liquid-filled balloons like the motor mounts. And, you likely wouldn't feel the diff mounts going bad unless you were in 4WD, which is hwy I asked about the model. Denali and Esky AWD drivers usually notice the diff mounts going bad.I added all the info, thx
At least you are getting it fixed !!! The OEM mounts are nice and quiet and soft.. they justI couldn't find a local shop that wanted to do the dreaded drivers side motor mount.. So I gave the dealer a few pennies, and they did it. He said 3 hours, but I'm sure an experienced guy can do it in 2 hours.
