OEM fog light kit installation
I can't see your pic or the ones in the link. The link says "photo not found" and yours has 'IMG" and a box with a square. The old thread is ok but remember Photobucket eliminated most folk's pictures a couple months ago. Probably should have just started a new thread but try re-posting some pictures and more info on the kit.
Not sure that I have image embed skills. Here's a link https://lfjennings.app.box.com/file/239729081461
That just takes me to a place that asks for your login password for your account. Don't "embed" images, upload them. At the bottom of the screen, next to "Post Reply" , there's a box right there that says "upload a file" which allows you to point to the file location on your device. Or you can right-click a pic, copy it, then when you're typing a response you can right-click and paste it.
OK, now hopefully somebody who has installed the kit has a clue what to look for. I sure don't! Good luck.
sick1166
you installed lights good ground. power to fuse box under hood,put in new switch headlight control with fog light control and done
Jmar73
IMG_3319.JPG IMG_3318.JPG Yeah, I think I got all those steps, but doesn't work. It's a ssv if that makes a difference.
The light on the dash isn't coming on either so I assume the computer isn't recognizing it.
Here is a pic of the switch plug, I noticed not all the pins have wires to the harness.IMG_3317.JPG
08SSV
I have the same exact problem (also ssv) no power at the fuse either. Hopefully somebody can shed some light on this.
Tahoe_SSV
Northern New Hampshire
I also would like to do this. My truck is 09 ssv also..I wish somebody would do a write up or video because this seems to be common thing people want to do and there is certainly a way to wire these up to factory switch.
kentf3
