HID to Halogen conversion
Kwayatron
Looking for advice on installing halogen lights on a 2016 Tahoe that was originally equipped with HID. There are a lot of aftermarket options but they all state that they're not compatible with HID equipped vehicles. What will it take to make these work? I bought the vehicle with no lights at all and I am not interested in spending $1,000+ to buy factory HID housings. I will likely end up fabricating a complete front clip for this vehicle and might just use some aftermarket universal type lights or pods. Can I just pull a 12-volt signal from the factory wiring and the circuit work properly? Does the computer need some sort of feedback from the factory HIDs for the switch to function?
bigdog9191999
sw michigan
i would think you could get an hid kit for a couple hundred that would work with the can-bus. may try the retrofit source for some research.
madmax442
