Replaced Thermostat and now bottom radiator hose is cold.
Cthomas
I replaced the Thermostat and now I noticed the bottom radiator hose is still cold even after I rn the vehicle. Any ideas what cold cause thi
Welcome to the Forum from NH.
Pics of the truck, please.
My first guess is that you still have air in the cooling system. What does the temperature gauge show when you are running the truck on the road?
Multnomah Falls
Welcome to your first post since joined over a year ago.
Suspect that @Joseph Garcia could be right but I wanna know why you were changing the thermostat in the first place?
Did you per chance install thermostat backwards or is that not even possible? Water pump problem? That is why I am curious why the thermostat was installed in the first place.
THarber
Make sure you burped all the air out of the system. These things are notoriously hard to get all the air out. You didn't mention if it was over heating or not either.
B-train
Year, make, model please. It will help us noodle on what may be happening better.
Phoenix2k9
