USB-C Upgrade?
Art Contoni
Central, IL
Anyone know if the 2017 Yukon dual USB-A can be swapped with the newer USB-C and USB-A or USB-C/USB-A/SD CARD
DougAMiller
Colorado
Pretty sure it will just plug in and everything should work. All of these that I have seen are just a USB hub regardless of what ports are on the front. It has a single mini USB plug on the back and a six-pin connector that provides power, ground, illumination and audio (if there is a 3.5mm AUX IN). I bought one of these to play around with and as long as you supply 12V and ground it can be plugged into a computer and everything works.
A
Art Contoni
Central, IL
Ok - thanks for the replies - I'll be the guinea pig.
Just ordered one on eBay hopefully here by the weekend...
Is there a preferred set of pry tools I should get - this is something I have procrastinated on buying since in the past you could get by with a mini flat blade screw driver most of the time.
Phoenix2k9
