Lifted/Leveled 2021 - Postem Up
FatDog
2021 Tahoe LT 4WD
1" Motofab "Level"
285/60R20 Toyo AT3's on the stock wheel
No spacers, no rubbing, no trimming
I wanted to go with the 3" Readylift SST kit and a little bigger tire, but the wife needs to still be able to get into parking garages. We really like how it came out.
Any more pics???
nick14226
Just went to do a little trimming to get the felt liner pulled back a bit more in the wheel well, anyone else run into this monstrosity or did they start it for the 22's? Could hook a chain to this thing and pull a tank out of a ditch. By BFH wasn't B enough. Took the cutoff wheel to the lower corner but sounds like I'm still rubbing in reverse at full lock so need to take more off.
olyelr
Elk Rapids, MI
Looks like a cover to protect some ac lines and maybe some wiring? Does it just unbolt?
nick14226
(4) very large bolts that are visible, going to try to pull off this weekend in order to cut and reinstall. Same piece mirrored on drivers side. Everybody stating trimming a little felt, pulling back and trimming plastic, etc, gotta think this is something newer. It’s pretty thick steel, thinking it holds everything in that corner together.
olyelr
Elk Rapids, MI
Sounds like it might dictate how much trimming can actually be done haaaaa
Ron505
