Barry Vaughn
- Joined
- Mar 20, 2021
- Posts
- 13
- Reaction score
- 9
going from 20' to 22's. How can I keep my speedometer correct? Does this require a transmission tune?
Thanks for the linkSince I always run summer and winter tires and they are 20's to 22's, and the diameters are different I use this tool. This is a good tire size calculator and will also give you the speedometer error if there is one, check it out,
Tire Size Comparison
Tire size comparison the easy way. Use our tire size comparison calculator to compare diameter, width, sidewall, circumference and revolutions per mile.tiresize.com
