Lifter tick help will mmo or motor flush help?
Trey Hardy
Trey Hardy
Eastern North Carolina
To be honest I don’t even remember I think it was valvoline high mileage 10w30 with a quart of marvel mystery oil and a k&n filter prior I would run royal purple 5w30 and a quart of Lucas but I took my diesel mechanic friends advice and I’m glad I did because she’s running a lot smoother before I switched it would lifter tap and I would peg it out and sometimes it would quiet up sometimes it don’t or it would come back either that evening or the next day driving it but so far since I switched I haven’t had any issues. And like above I’ve drove it probably close to 10-15 hr within a couple days time traveling for work
B-train
I would change out the oil and filter soon. The MMO has probably washed the heck out of the motor. Or, depending on the miles you've put on, change out the filter and top off with new oil and let the cleaning continue. You don't want the filter to get so restricted that it starts to bypass......then all the potential good you've done has been a waste and just moved gunk to other areas that never see gunk. $7-10 for a filter and $5 for a quart of oil might be worth it. Also, try the PF63 filter. I believe it's the same diameter as the OE one (double checck visually on o-ring and thread), just twice as tall and more filtering capacity. I use PF63 on both my 08 and 17 Denails.
Trey Hardy
Trey Hardy
Just now changed the oil and filter at 2000 miles cause it make a slight noise on the way home last week same thing 10w30 Mobil one high mileage synthetic and a quart of mmo k&n filter again so far so good oil was definitely dirty but no where near as gunky as I thought it was going to be
B-train
Keep us posted. It will be interesting to see what your final outcome is. Thanks for the update
Trey Hardy
Trey Hardy
Yea my buddy said he might try it on his cause his done the same thing and he quit driving it I’m not saying it’ll be a long term fix but if it stretches out the life of this old 5.3 where I don’t have to tear it open until I have another motor ready to drop in I’ll be happy the trip today was 3.5 hr straight pretty much 75 from the time I left the house lol so far so good
Trey Hardy
Trey Hardy
It’s now almost the end of February I’ve been adding mmo for my last quart of oil each oil change now and my lifter tap/stuck lifter has not come back yet! Knock on wood…
She leaks almost a quart between oil changes so I add Mobil 1 when it becomes low so the mmo does not thin the oil out to much.
Definitely not saying this is a permanent fix but it saved my ass is all I can say!
Almost 320-330,000 miles on it now!
B-train
Sweet! Glad you are able to eek some more life out of her. I'd assume the inside is quite clean by now. You might be able to go back to just oil at this point and see if it leaks less. Hopefully you park on asphalt or gravel. LOL
Trey Hardy
Trey Hardy
Not horrible but still want to trace it out if possible
Also my yoke has been like this ever since lifting it im assuming I would need a longer yoke or extended driveshaft? Not problems so far but figured I’d get y’all’s opinions
Got new u joints I have to make the time to install
B-train
Looks like you got yourself a good old fashioned rear main seal leak there sonny. Along with possibly an oil sender,valve cover gaskets, and whatever can give up at 325k. LOL
I'd probably address the driveshaft sooner than later. I know they slide in quite a bit to make up for suspension travel, etc. But seeing your suspension is always traveling......away, you'll probably want more contact on the output shaft splines before they cease to exist.
wbhidalgo17
