89Suburban
Bull in the china shop
SE PA
I didn't think they put the Nivomat's on the gmt900's but if they are the rear shocks are much larger looking than normal and they are expensive.
I have nivomats..... They are configured within the shock it's self.
( Why they are pricey)
Can I just put regular shocks on it instead??
89Suburban
SE PA
It's been done.... I am sure there are threads to show how...
it may require a bit more than 2 bolts to R&R a shock.... maybe coil springs too?
Someone will chime in.....
I just ordered a 2" rear drop kit so the springs are getting swapped out anyway.
mountie
Guys, I am shopping for rear shocks and I see many notes about a ZW7 code. I do have that code on my RPO label. But I just have regular looking shocks. I looked up that code and it says premium ride with Nivomat self leveling?? I see no trace of that under my truck. No hoses or pump or anything. Does that mean the PO removed all that stuff???
To be clear, the Nivomats are self-contained and do not have wires, hoses, or other connections (other than the physical mounts). Your '07 doesn't have Nivomats.
89Suburban
SE PA
Here is my RPO. SO I can just order regular shocks even though I have that code on it?
GeorgeC
