Today I joined a FB group of Escalade Enthusiastes. For a first post I described what we are doing to my 06 Escalade and included a vidoe of a dyno run for the LS364/450 we installed. I purposely didn't post hp and torque numbers. Almost immediately someone asked for them. I stated the numbers the tuner calculated from the rearwheel dyno are 452hp and 447ft-lb torque at the flywheel. I was then criticized for posting "calculated flywheel numbers" since "they are irrelevant."
Am I missing something here? I know the rear wheel numbers are lower than flywheel numbers. However, I also am aware using properly qualified correction factors and accurately (within reason) calculated flywheel numbers for this engine lets me it is performing in the range of the manufactures published flywheel specs. I'm at a loss as to why some folks don't get this, since manufacturers use flywheel specs to quote hp and torque.
