Stripped out rear caliper bleeder screw hole
JamesLond
I rounded off the original bleeder and replaced with a brake best brand bleeder. During tightening I stripped out the hole though.
The screw is out but I think I might have to replace the caliper. Do I have any other options?
MassHoe04
Western MA
Sorry, man! I feel your pain. Been there, done that.
X2 on replacement.
That is a hard lesson to have to learn.
I looked up in the FSM. Bleed screw torque is only 106 IN LBS. That is only 8.83333 Ft. LBS.
That is not a whole lot... Just enough to block fluid from slipping through.
J
JamesLond
Alright, I grabbed another one at Autozone.
What a pain.
I actually installed a Dorman 13908 at first and I did notice I had to work to get the thing to stop leaking out.
At least to save someone else this problem, I'd say just go OEM even if your dealership is a little out of the way.
rockola1971
Indiana (formerly IL)
Well that is a first. Ive never heard of anyone stripping out a thread in a caliper.(rounding off bleeders sure) Were you using an impact to install it? Or a 1/2" ratchet with a 4ft pipe on it? :p
Blackcar
What a pain.
I would say there was probably something wrong with new bleeder screw you tried.
J
JamesLond
Trust me, it happens. Especially, when you use aftermarket stuff.
Oh yea, for anyone getting a caliper locally, make sure the bleeder on the replacement is the same size as the originals. I had to pull the caliper off again and install another after I realized the bleeder was way wider.
If it ain't the same and I strip the screw, then I'd be driving all over trying to find a size that fits since the replacement would fit like a hot dog in a hallway.
On the next generation, the calipers in the back are aluminum and use a different thread for the bleeder. You can use 1/2 of a rebuild kit for the front calipers to rebuild one of these single piston rear calipers.
Willis12345
