Just Fishing
Can't fix stupid
Utah
Fixed my airbag light for $135 (part cost).
Now I'm looking at the TPS sensors and seat cushion.
I pulled back the seat cover to see if I could fluff it up using a steamer.
Answer was yes... sort of.
The side of the cushion is shredded, so I stuffed some of the foam packing from my coldcase radiator in there after re-fluffing the foam up.
It's lumpy, but it's already better than it was. :jester:
Just Fishing
Can't fix stupid
Utah
I lied,
Apparently, my rear window slop is forward and backwards when the windows are rolled down.
I don't see anything wrong/missing, is that normal?
pwtr02ss
Tennessee
I lied,
either the window glass came loose from the regulator or the regulator is bad, take the door panel off and wiggle it and you should be able to see.
a4edwin
ny
My airbag recall took 15 minutes to replace. I had barely sat down in the waiting room and thought about if it was worth using their coffee machine, or if I'd catch E. coli from it, when the tech came in to say it was done.
I used it. Don’t judge me!
Just Fishing
Can't fix stupid
Utah
Yeah I can see it wiggling on the regulator.
bolts tight, but I'm guessing their special child probably rocked that window back and forth.
I did get it to tighten up a little by removing and reinstalling the inner window seal.
But it looks like if it bothers me enough, then it's new regulator time.
Or i can try and find some way to fill in the slop...
I'm going with "meh!" for now.
Just Fishing
Can't fix stupid
Utah
