AN292
- Joined
- Feb 19, 2020
- Posts
- 118
- Reaction score
- 97
Got that single metallic pop noise when turning left forward/reverse, sometimes does it 2-3 times. Full lock or near full lock.
Parts that are new:
Inner/Outer tie rods
4 new shocks
Upper control arms
Eibach sway bar and end links + new bushings
No bushings/boots are torn, nothing is loose. I've checked for bearing/hub play, everything is solid in that regard.
I have heard of the cross member bolts needing to be tightened. It doesnt happen when turning right.
All those parts are 1 year old, except for the upper control arms, which are only 2 weeks old. ACDelco or Moog used. The noise was happening before the uppers were changed out, thought that would fix it.
Parts that are new:
4 new shocks
Upper control arms
