donjetman
- Joined
- Oct 22, 2018
- Posts
- 1,363
- Reaction score
- 2,360
I recently changed the ATF & filter. I took a sample with a JG Lubricant Services used oil analysis kit. They use Polaris Laboratories. Sent it in and 5 working days later here are the results. This is the same fluid and filter as before (see result #1).
Lab flagged the viscosity of 5.6, so I called Tom Johnson of JG Lubricant Services. Tom is co-owner of JG Lub. He spent 30 yrs with GM/Allison as a fluids engineer. He said when viscosity gets to 5.5 they recommend changing the fluid. When viscosity gets to 5.0 bushings etc start to wear. So my timing this fluid/filter change worked out good. Not too early, not too late.
Tranny has 174k miles since new. 43k miles ago, while doing the engine rear main seal job, I replaced the original torque converter as a preventative mx item. That was the last time I changed all the fluid and the filter.
