New to me 2007 Suburban
89Suburban
Bull in the china shop
SE PA
Oh ok I thought you got the PPV rims already.
stocksj
stocksj
Brandon, FL
You have a link for the PPV's you were talking bout?
The company was called partsgeek.com, they said they had rims for $88 but were out of stock. I'm waiting for my money to be refunded. About any auto parts place may have PPV rims plus they show up on FB Market place usualy after you moved on to something else. I'll keep and use what I have for now since they kind grow on you. Plus I have new tires on them so I'll get my moneys worth out of them.
stocksj
stocksj
Brandon, FL
Question, How difficult would it be to add the same type of additional cooling items on a stock Suburban/Tahoe LS? Thinking about Trans and oil cooler.
stocksj
stocksj
Brandon, FL
The company was called partsgeek.com, they said they had rims for $88 but were out of stock. I'm waiting for my money to be refunded. About any auto parts place may have PPV rims plus they show up on FB Market place usually after you moved on to something else. I'll keep and use what I have for now since they kind grow on you. Plus I have new tires on them so I'll get my moneys worth out of them.
I finally got my refund yesterday from partsgeek.com. Took a few days longer than expected.
Not too bad if its RWD right? You'll replace the radiator and to do that and add the external transmission oil cooler you would pull the front passenger wheel and move the front of the liner out of the way or pull it entirely out for the job and also remove the bumper cover. My daughters and I have done it a couple of times. Well, they tell me to go sit down and do it now!
stocksj
stocksj
Brandon, FL
Okay, here’s another issue with the SUV, I know nothing is perfect in a used vehicle. While running the AC the last few times I noticed that the driver side blows cold air and the passenger side blows hot air. I’d seen something about a blend door under the dash that needs fixing to correct the problem? Thanks
Cbrpilot2
