Can you reprogram with a Tech2, or does that require something else?If you buy just the gauge face the cluster will need to be programmed as the MPH is printed different.
to the best of my knowledge the tech2 will only program a new never used cluster, after that it requires special chip programming tools which is what the gauge repair shops useCan you reprogram with a Tech2, or does that require something else?
